#16 |
So this Actually Works!!!
Thanks Tonnes!!!!
1st laptop - Dell wireless built in 2nd laptop - Panasonic Toughbook wireless PCMCIA card 3rd - Palm Tungsten C Hand held Works like a dream! Thanks Again!!:thumbup: |
#17 |
Adios!
Credits: 0
hehe, any tricks for ICS on windows 98?
#18 | |
Dell i600m: in a d600 chassis|1.6 Dothan => undervolted (Min vid: .7V, Max: .988V) => USB Modded => Bluetooth Modded How-to: Wireless Dial-up |
#19 |
Porsche Carrera 4S
Credits: -295
What Wireless Routers do you recommend?
Nice Write Up...
A quick question... What Wireless Router do you recommend when using the Dialup wireless feature? Thanks, Gadgetman Last edited by Gadgetman; 03-09-2006 at 07:35 PM. |
#20 |
If you have to do it that way, I recommend that you use two routers: Get an older (don't believe they make them anymore) WIRED router that has a dial-up modem inside. And connect that router to a regular wireless router having the settings I described. This has the benefit of upgrading your wireless router in the future to better technology.
#21 |
ics option not showing up ?
Hi Mich43l I am try to help a friend set this up but then i got to the
ICS Setup on Desktop this is the screen i get only firewall do i need to run the netwok wizard so the ics options will show up it is winxp home sp2 thanks for any help beau Last edited by n9mfk9; 03-10-2006 at 01:01 PM. |
#22 |
Porsche Carrera 4S
Credits: -295
I Need Help!
I bought a Linksys Router (WRT52GS) and I cant get it to work using wireless dialup. I called Linksys Help desk and them told me it will not work on dialup. I asked if there was another model that will work and the supervisor said no. What are you folks using? Darren |
#23 | |
It will work on virtually any regular wireless router that has standard ethernet ports including the WRT54GS. Follow the directions. Bring down your firewall (both on the client and the server). If all else fails try bringing down the MTU to 1420 on the router but it shouldn't be a problem.
#24 |
Porsche Carrera 4S
Credits: -295
I spent all night trying to get my dialup wireless to work. I'll try again later. When I set up my router, I didnt have "Obtain an IP automatically". Mine said Obtain DHCP automatically. I have DHCP disabled. Maybe the setup on my desktop isnt correct. I dont see a dial up connection on my Network Connection screen. I deleted it because it brought up netscape dialer. Any ideas what may be wrong? |
#25 |
I am new here at the Forums.I am not New to Forums.I belong to and mod at other sites.
Also you've done your homework you get an A+. Thanks All! SSDA67 |
#26 |
Porsche Carrera 4S
Credits: -295
Phew, I did it! I got dialup sharing working.
#27 | |
Credits: 3,601
http://www.geekzone.co.nz/content.asp?contentid=5647 A review of it here.
Dell Precision M4400,P8600,2 x 320GB,xpp,wxga+led,fx770m |
#28 |
hi mich43l
I got the ics working good but i have found on problem when i programed the router i used 192.168.2.1 but now with ics up i can not get back in th the router to forward ports thanks for any help to net around this beau |
#29 |
:O people still use dial-up? even with all those comericals on the tv saying go to bell south ,comcast, and all those other things that gives speeds 400 times faster than dial-up for 40-60 bucks a month.. amazing.
but its a good guide but i dont know anyone who would use it unless to learn how to hook up wireless dialup. |
#30 | |
| dial up wireless, yes you heard me right | dory | Notebook Forums - General | 2 | 04-11-2006 08:03 AM |
| Wireless Dial Up ? | AJAX | Other Brand Discussion | 4 | 11-12-2004 10:43 AM |
| Wireless Dial Up ? | AJAX | Toshiba Notebooks | 0 | 11-11-2004 10:19 AM |
| 56k Dial-up Wireless? | BUD212002 | Sager & Clevo Notebooks | 5 | 12-30-2003 11:29 AM |
| Wireless Dial-UP | Eric | Sager & Clevo Notebooks | 9 | 11-29-2003 08:40 PM |
