Thread Tools | Display Modes |
#16 |
drum while you work
sticky!!
Notebook Forums Moderator & Administrator 590 bans and counting... |
#17 |
Credits: -341
if u use this tool u might be able to find out the ram, hd speeds
http://www.crucial.com/uk/systemscanner/ i dunno if it recognises the W3J (being a newer model)..but it works fine on my old toshiba.. try it out.. additionally u can also check it in the Bios (for most bios es atleast)... Last edited by nocturne_sa; 04-22-2006 at 01:28 PM. |
#18 |
i was kind of hoping for 4+ battery life but i guess 2-3 hours is ok with that graphic card. but everything else is perfect!
#19 |
Credits: -341
#20 |
Credits: -348
The wj3 could be my next notebook but i have some questions.
Ive seen weight claims on both 2 and 2.2 kg but wich one is right, maybe differnt batteries? Or do you have a scale that you could use so we would know for sure. And was dvd problem you had hard to fix or a simple one. How is the heat and sound level if you run some heavy programs or games for an extended amount of time. |
#22 |
Credits: -346
Glad to see you got the DVD issue worked out. I am also really impressed with the 3dmark score (of course, you can get that higher if you overclock). But that is something I will be a little hesitant to do once I get mine. Also glad to hear that heat wasn't an issue. I have been on the pre-order list for nearly a month. The w3j has been pushed back nearly a month in the states so all of these positive reviews are only making it harder and harder to wait. But much more worth it I suppose. I'm glad you're happy with your purchase.
#23 |
I just found out from asus the hard drive speed is 4200rpm.
Further tests are showing the heat stays around 54C whilst I was burning a lot of dvds, battery life is staying around the 2 1/2 hour mark (working in photoshop, word and surfing online with wifi and bluetooth active). I did try playing doom 3 at close to native resolution whilst the dvds were burning and there was quite a loss in frame rate, so much so that I couldnt play. This may be normal but I thought this is what a dual processor is for? Maybe I was pushing it too much but I am a little disappointed with that Watched a full dvd on battery and it did skip for a split second every 10 seconds or so but you may not notice this if you arent looking for it. Its only really noticable on pan shots and you have to concentrate hard. The aluminium lid does leave fingerprint marks all over it but are easy to wipe off. Still a great laptop but the above points may help you in your decision
http://www.soulrevolver.com |
#24 |
Thanks alot for the review!!
Yeah thought the English version hard drive is 4200rpm, but you can upgrade it at www.asuslaptop.co.uk to 5400rpm for 109+VAT, or stick in a 60gb 7200rpm for 99+VAT. Tempting! Anyword on the RAM speed? |
#25 |
Registered User & Abuser
Ted, where are you from?
They speculate that US will be the only 5400 rpm w3j's.....im kina worried doom 3 is hard drive intensive, so it might be lagging because of your 4200 prm drive. |
#26 |
If might be worth upgrading your hard drive... Stick in a 7200rpm drive and all the lag you talk about may disappear. Its a real shame they stuck a 4200rpm drive inside. This is probably your bottleneck in your system.
| Asus V6VA | P-M 2.13Ghz (AS5 & undervolted) | 2GB Corsair Dual Channel DDR2 533MHz 4-4-4-12 | DVD Super MultiDrive incl. DVD-RAM | 15.1" SXGA+ IPS, Crystal Shine & Color Shine (truly amazing screen) | ATI Radeon x700 (stock 345/331) | Hitachi 80GB 7200rpm 8mb cache | XP Pro | ~2.5kg with 8 cell battery, even lighter with 4 cell | | Toshiba Tecra M3 - No room for more details| |
#27 |
wow this laptop is very compact and it's capable of playing games...
it's only 20% less powerful than my desktop- freaking awesome |
#28 |
Credits: -367
wow! thats a great looking piece. enjoyr ur new lappy.
#29 | |
Credits: 164
#30 |
Asus W3J on pre-order... |
| Review: Asus Z71V- 4 years and still going strong! | Djembe | Asus Notebook Reviews | 179 | 07-11-2009 10:13 AM |
| Review: Olli3's - Asus Z71V User Review | olli3 | Asus Notebook Reviews | 134 | 05-06-2009 06:00 AM |
| Review: (my) Asus z70va point-form review | dimalife | Asus Notebook Reviews | 16 | 11-06-2005 12:41 PM |
| Review: Suur's grand Asus a2500k review | Suur-Marsu | Asus Notebook Reviews | 2 | 12-13-2004 07:19 PM |
| Review: Matt's Asus M6BNe Review (no pics yet) | mawst95 | Asus Notebook Reviews | 12 | 09-17-2004 09:52 PM |
