Old 10-25-2006, 06:08 AM   #31
Dalantech
www.dalantech.com
Dalantech's Avatar
Credits: -318
Dalantech is a n00b, but everyone loves n00bs!
Thanks!
As long as the LCD is as good as, or better, than the one in my current laptop (Vaio S560P) I'll be happy.
Network News and Reviews
Dalantech is offline   Reply With Quote
Old 10-27-2006, 11:24 AM   #32
wuzuprad
wuzuprad is a n00b, but everyone loves n00bs!
looks pretty good. Thanks for posting the pics and all the info. Excellent job good sir.
wuzuprad is offline   Reply With Quote
Old 10-28-2006, 09:43 AM   #33
MilestonePC
Credits: 3,813
MilestonePC has disabled reputation
Here is the A8js 3DMark06 2665. Stock settings:
The laptop performed very well here, Nvidia has a tendency to perform better in 3Mark06 then ATI, but just marginaly.
As other have reported gaming on this laptop is great.
Some here are asking about the screen and it's viewing angles, well to be honest, the angles remind me exactly of the A8jm. I would say the view angles are the same or little better or worse than the a8jm.
For those who do not know much about the A8jm, the viewing angles are a little restrictive, around 100 degrees to 110 degree.
MilestonePC is offline   Reply With Quote
Old 10-28-2006, 02:37 PM   #34
wuzuprad
Hey thanks for this little bit of info as well. Anything that anyone can post about this machine would be awsome. Still lookin to see if anyone has any Half life 2 benches or stats for this machine. Thanks!!!!
Old 10-28-2006, 06:04 PM   #35
mayaman2
For the Emperor!
mayaman2's Avatar
Credits: 694
mayaman2 is a n00b, but everyone loves n00bs!
Have you tested the temperatures after gaming for quite some time?
Recovering post ho. I work at Siemens now. Hehehe. They don't make submarines either.
Green on the outside, red on the inside. Perhaps a watermelon or a guava should be the sign for the go green movement?
mayaman2 is offline   Reply With Quote
Old 11-08-2006, 07:40 PM   #36
jasn
jasn's Avatar
Credits: 4,830
jasn has disabled reputation
Stock, "out of box", Asus windows install (only uninstalled Norton), results;
3DMark03 - 10086
3DMark05 - 4306
3DMark06 - 2690
COSBI OSMark Version 1.0beta7a - 1768
Geekbench 2006 Build 230 - 263.4
SiSoftware Sandra Lite 2007.SP1 - 5030 (Performance Index - Combined Index)
jasn is offline   Reply With Quote
Old 01-17-2007, 12:41 PM   #37
Entropius
Credits: -136
Entropius is a n00b, but everyone loves n00bs!
Half-life 2, as far as I can tell, runs smoothly maxed out at 1440x900.
eMachines M6811 | Mobile Athlon 64 3400+ | 15.4 WXGA | Radeon 9600 64MB | 1280MB DDR1 RAM | 80gb 4200RPM disk | Gentoo Linux/Windows XP | 2:55 battery | DEAD due to cracked hinge problem
Asus A8Js | Merom 2GHz 4MB cache | 14" WXGA+ | Geforce 7700 512MB | 1024MB RAM | 120gb 5400RPM disk | Gentoo Linux/Windows XP | 3:00 battery
Entropius is offline   Reply With Quote
Asus A8Js 5750FTW Asus Notebooks 4 05-06-2007 03:40 PM
Asus A8Js or G1? AdreeN Asus Notebooks 9 04-03-2007 09:01 PM
Asus A8JS - Question about Ram Wiggins Asus Notebooks 3 03-15-2007 06:38 PM
Asus G1 / Asus A8JS / Compal HGL30 devarshi84 Asus Notebooks 17 12-21-2006 11:22 PM
Few Questions on Asus A8Js mm1999 Asus Notebooks 2 11-14-2006 05:15 AM
