Old 06-11-2007, 09:03 PM   #1
zzpulp
@laptopvideo2go.com
zzpulp's Avatar
Credits: 9,063
zzpulp eats n00bs for breakfast.zzpulp eats n00bs for breakfast.zzpulp eats n00bs for breakfast.zzpulp eats n00bs for breakfast.zzpulp eats n00bs for breakfast.
yes but my guide also states that it has taken me up to 1 hr or more to get the numlock led's to turn on (and another 30 to flash the card). That's why I recommended the overnight. The cd method works fine for me but some other ppl have said it does not work.
zzpulp is offline   Reply With Quote
Old 06-11-2007, 10:23 PM   #2
yolda
yolda's Avatar
Credits: 20
yolda is a n00b, but everyone loves n00bs!
hmmm so the boot thumb drive should take care of that "lag"?i think i will try it.
Common e1705 with a T7400 ES, a 7900GSX scoring 9700 in 3DMARK05 and lots of emule-ware
Visit http://alvarofrank.blogspot.com/ if you feel like reading something strange on another language.
yolda is offline   Reply With Quote
Old 06-11-2007, 10:45 PM   #3
zzpulp
@laptopvideo2go.com
zzpulp's Avatar
Credits: 9,063
I know you're probably not reading this now but what do you mean by lag? It will take just as long to boot to cd as it will usb, actually the cd does take about 1 min longer. I'm just saying to be on the cautious side to use a bootable usb. Besides, bootable usb is a nice tool. I have various dos executables on mine.
Old 06-12-2007, 06:17 PM   #4
yolda
yolda's Avatar
Credits: 20
i wil try to use the usb bootable device, but i did an overnight boot up and got no numlock response, so i guess im screwed. Tomorrow the same technician will come and replace the mobo, (i know thats not the problem but i coulndt say it wasnt without saying it was my fault
Old 06-12-2007, 06:46 PM   #5
zzpulp
@laptopvideo2go.com
zzpulp's Avatar
Credits: 9,063
Huh? You did an overnight boot with no boot media? Or did you have your HD in? The numlock turns on to show the bios has initiated. Once the bios boots a device the numlock typically turns off (say it boots an OS, however, not for flash drives typically). Like I said as a final shot, take all media out in the form of HD, usb storage, cd media, sd, what have you and just put in one flash drive. Leave it overnight and if you still dont have a screen using my nvflash and "nvflash -4 -5 -6 -A -y [romname].rom" then you are just screwed.
Old 06-21-2007, 12:09 AM   #6
HaCKs
Dude you're gettin a Dell
HaCKs's Avatar
Credits: 567
HaCKs is a n00b, but everyone loves n00bs!
7900gs
So I made a working boot usb key (tested in another system) and I turn the laptop on, the backlight does not come on, nor does the numlock ever work, I have left it on two hours now with no result, I am going to turn it off and on and off and on to see if that helps, but if not the new motheboard and video card come from dell tomorrow, so we'll see.
HaCKs is offline   Reply With Quote
Old 06-21-2007, 01:15 AM   #7
zzpulp
@laptopvideo2go.com
zzpulp's Avatar
Credits: 9,063
Well, I really don't know what to say.
Although I will mention that its always a good idea to get a feel for a system before you start hacking away at it.
Old 06-21-2007, 03:08 AM   #8
HaCKs
HaCKs's Avatar
Credits: 567
Its okay, tomorrow I should get the parts (latest friday) and I just rebuild and hope for the best.
Old 06-21-2007, 09:03 PM   #9
yolda
yolda's Avatar
Credits: 20
well some interesting news, if you cntrl alt del a videobios flash, your motherboard will be dead too... have that in mind
Old 06-23-2007, 04:10 AM   #10
zzpulp
@laptopvideo2go.com
zzpulp's Avatar
Credits: 9,063
Thanks man. Anyway, I have a 6800go bios that I think I backed up from my roomate's stock 9300. I do not have any room left to attach it here and its a bit long to post with the Code tags, but if you give me your email I can send it.
Old 06-25-2007, 03:13 AM   #11
lifemaelstrom
Credits: -340
lifemaelstrom is a n00b, but everyone loves n00bs!
Omg It Worked I Love You I Love You So Much Thank You Thank You Thank You
lifemaelstrom is offline   Reply With Quote
Old 06-25-2007, 04:37 AM   #12
Ensui
Credits: -337
Ensui is a n00b, but everyone loves n00bs!
I wish I was having the same luck. It's going through the finalization process with the double beeps and whatnot, but when I restart the comp I get nothing on screen. Looks like I'll have to pay the $200ish for Dell to fix it. :\
Oh, I found another command line another board, but I wanted to get some opinions before trying it.. it would go...
nvflash [romname].rom /py /sn /cd /cp /cc
Ensui is offline   Reply With Quote
Old 06-25-2007, 06:21 AM   #13
zzpulp
@laptopvideo2go.com
zzpulp's Avatar
Credits: 9,063
Type the exact command you are using in your autoexec here so I can see it Ensui...I hope you are using the Ultra.rom I gave you and not the other one.
Old 06-25-2007, 01:22 PM   #14
Ensui
Credits: -337
nvflash -4 -5 -6 -A -y ultra.rom
My flash drive consists of four files..
ultra.rom
nvflash.exe
cwsdpmi.exe
autoexec.bat
After about an hour I get the dual beeps, albeit it's usually so random that I miss whether or not the lock keys cycle or not. After this beep I've let it sit for another hour and restarted via the power button with no results. I've attempted a couple over nighters with nothing too.
Old 06-25-2007, 11:51 PM   #15
zzpulp
@laptopvideo2go.com
zzpulp's Avatar
Credits: 9,063
Ok I am doing some work right now but before you give up, I'll be back later today for one more autoexec that can confirm your card status.
i need help with the blind flashing procedure lilflippy Dell Home (Inspiron, XPS, Studio) 7 11-18-2006 12:40 PM
am i blind?? [GBU]Moon Dell Home (Inspiron, XPS, Studio) 7 09-29-2005 05:39 PM
MY computer is BLIND!!! monkeyboy070 Alienware Area-51 and Aurora Notebooks 15 06-30-2005 11:32 AM
Am I blind? Jumbie Dell Notebooks - General 5 06-24-2004 05:22 PM
Pixel Blind dashby Notebook Forums - General 2 01-21-2004 10:48 PM
Copyright Đ 2001-2009 NotebookForums LLC
