#91 |
Credits: -337
You are seriously too kind. They need to make you an admin around here or something.
#92 |
Nah, we are all pretty much useful users around here, but I guess I'm the resident jackass. I went through the whole phase where I was prepared to just break my card and get a x300 for the sake of battery life and heat.
Anyway, I've been up to some exams so I've been a little busy. I know how much it sucks to have a non-functional computer just sitting there. Try out this autoexec (only works for flash drives as cd-r's aren't readily writeable in clean dos) First, copy ultra.rom to a file named temp.rom Be sure to copy it and not to just rename it Also, be sure to use the nvflash I have uploaded here Code:
nvflash -r nvflash --list > output1.txt nvflash -c > output2.txt nvflash -b diag.rom nvflash -k diag.rom > output3.txt nvflash -4 -5 -6 -A -y temp.rom del temp.rom Now I want you to leave that, and provided the card still isn't working, I want you to post the contents of output[1-3].txt here or attach them here or email them to me (whichever you prefer-if you email em be sure to post here so I know). |
#93 |
Credits: -337
Will do sir, I'll post the reply here in case someone else reading this thread is having or will have this issue.
I should have the results posted at 00:30 eastern time tonight. |
#94 |
Credits: -337
Or maybe not. After leaving it in for an hour and a half, doesn't seem like the flash drive actually did anything since there weren't any output files created. I should have something for you in the morning though, as I'll just leave it in overnight and hope it works. Thank you again Mr Pulp.
#95 |
Credits: -337
Left it in overnight, nothing changed on the flash drive. Still has test.rom in it and it didn't create the output.txts. :\
#96 | |
Doesnt sound good. Every time I have seen a system that does not boot after a given amount of time it has turned out that the graphics card is just dead (using all practical means to recover it). But I am anal and I like proving these things and not just assuming. If you arent like me then you can disregard this quote:
#97 |
Credits: -337
I'll try out this command string and see if it makes anything...
nvflash --list > output1.txt nvflash -c > output2.txt nvflash -r > output3.txt nvflash -4 -5 -6 -A -y temp.rom > output4.txt Should there be any reason why it's not producing the output files? |
#98 |
yes, the reason is that the bios is not even initiating. If you dont have the system led's (the eye candy ones that only come with xps) set to turn on upon bootup (I usually disable that but its enabled by default) then it would be a little difficult to set that up now without seeing the screen. If it is setup like that already then the led's coming on would indicate that the bios has initiated and is POST'ing
The other autoexec is no better than the one I listed earlier. The main point was to show you that the laptop can boot sometimes and not boot other times. In my case it was like 35% of the time it booted with a dead 7800gtx. If you are having problems booting even after extended periods, then most likely, your card is dead but if you really want to prove it you will want to keep trying to make it boot. Last edited by zzpulp; 06-28-2007 at 01:11 AM. |
#99 |
Credits: -337
You are right that the LEDs are turning on, luckily I didn't turn those off. So they do turn on, making me figure that the PC is posting, especially since I can run the FN Key Diagnostic and the keyboard seems to respond if I hit caps/scroll/num lock (if that makes a difference).
How can I tell if it really booted or not though? Just keep trying every hour and a half, then reboot if there are no results? |
#100 |
If your system led's turn on and you leave the card for an all-nighter and it still doesnt respond, I'd say to start looking for someone to buy a new gpu from. Your options, in this order, are x300, x600, 6800go, 6800go ultra, 7800go gtx
#101 |
Credits: -337
Will do, thank you for your help.
![]() Oh, um, I just thought of something last night. I know before I did my flash, I uninstalled my vid-card drivers since I was going to update with new ones from laptopvid2go after the flash. Do you think the fact that my vid drivers aren't currently installed would affect anything? Last edited by Ensui; 06-28-2007 at 02:10 PM. Reason: Oh. And one more thing. |
#102 |
Oh, didnt know you edited your post. The video card drivers are just a way for your operating system to access the resources of your gpu. What we are doing with the videocard bios is controlling what those drivers would access. Hence we are performing low-level "modding" independent of the drivers.
Short answer: No. |
#103 |
Credits: -337
Posting in this thread as requested. I think I probably killed the video card as well. I'm not sure if the num/caps/scroll locks cycle when it flashes; It usually takes an hour or so for it to do it, and I'm either not looking at it or not near enough to it to see it in time, unless the cycling is something that keeps happening.
In any case, the only constant is the numlight LED comes on and stays on after a while. Then I'll get two beeps out of it, and nothing happens. Read through and I'm in the same boat as Ensui, almost exactly. I'll do the commands you gave him with output.txt files. Last edited by sevenflow; 07-23-2007 at 05:45 PM. |
#104 |
Sounds recoverable as it is performing just like my defunct 6800 ultra. Just tell me which autoexec you are tried/are gonna try.
#105 |
Credits: -337
nvflash -r
nvflash --list > output1.txt nvflash -c > output2.txt nvflash -b diag.rom nvflash -k diag.rom > output3.txt nvflash -4 -5 -6 -A -y temp.rom del temp.rom Going to try that, and paste the txt stuff here so someone better at this than I can interpret Uh oh, page 8 Last edited by sevenflow; 07-23-2007 at 07:33 PM. |
| i need help with the blind flashing procedure | lilflippy | Dell Home (Inspiron, XPS, Studio) | 7 | 11-18-2006 12:40 PM |
| am i blind?? | [GBU]Moon | Dell Home (Inspiron, XPS, Studio) | 7 | 09-29-2005 05:39 PM |
| MY computer is BLIND!!! | monkeyboy070 | Alienware Area-51 and Aurora Notebooks | 15 | 06-30-2005 11:32 AM |
| Am I blind? | Jumbie | Dell Notebooks - General | 5 | 06-24-2004 05:22 PM |
| Pixel Blind | dashby | Notebook Forums - General | 2 | 01-21-2004 10:48 PM |
