Thread Tools | Display Modes |
#61 | |
#62 |
Credits: -150
if i were to get the acer ferrari 3200 how hard would it be to just replace the harddrive with a 7200 rpm one.
also where should i purchase one im a n00b at this sort of thing. thanks |
#63 |
Credits: -343
it's very easy to replace the HD. i did it myself in a few minutes. you unscrew a small section of the case, pull out the bracket, swap the new HD into the bracket, and push the bracket back in. screw the cover back on and ur done. no cables or anything to fumble with, so much easier than a desktop HD swap.
#64 |
Crazy AJ
One last look for the L2... I went back, doubled checked AMD's site, finally noticed where the low-power architecture was hiding... For the curious, go to the following link... http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_10220_10221^10234^11031,00.html Note: Up in the diagram it states there is an L2 Cache of 512KB, but down in the specs it says "Up to 1MB Level 2 cache"... I'll be curious if/when a change over might occur, or for which speed processors will have it, and if it would be publicized... |
#65 |
Credits: -329
I would be all over this laptop if it wasn't so.......red.
#66 |
Credits: -326
If i was to swap the hard drive for a 7200 rpm 60 gig, how hard is it to reinstall the hard drive, and how do you go about doing that
#67 | |
http://amd64notebooks.com/phpBB2/viewtopic.php?t=327 Last edited by snorre; 06-15-2004 at 03:44 AM. |
#68 |
kmarshal,
I swapped the Toshiba 80gb 4200rpm hard drive with a the Hitachi 7k60 and it was as easy as taking out the two screws that are directly under the mic/line in/audio ports. Once that is off the cover for those ports should come right off. Then once you slide the old hard drive (with bracket) out, take out the four screws that hold the hard drive into the bracket, and replace it with your new hd. put everything back into place. All you have to do for recovery is go into the bios and make sure the cd-rom drive is selected first in the boot order, then restart with the system cd in and follow the on screen instructions for the rest of the recovery process. very easy. the whole process took me less than half an hour.
My Rig AMD 3200+ Venice 1GB Patriot 3200LLK 74GB Raptor 7800GTX Lian-Li V1200 |
#69 |
Credits: -150
thanks, when mine shows up ill do that
#70 |
Credits: -138
Is there any possibility of adding a second HD to this beast?
DELL Inspiron 6400 C2D T7200 2G DDR2 667 120G 5K4 HDD x1400 GFX 15.4" SWXGA |
#71 |
only externally.
#72 |
man, I just have to say thanks guys. this thread has been really informative in helping me decide to order this notebook (my first portable). Reading that it is possible to tweak and replace parts to my needs sold it for me. thanks guys, I am off to go order this puppy.
questions coming soon I am sure... ![]() |
#73 |
Credits: -341
Hmm What about cpu upgrades.
Do i void the warrenty? what is low power worth, to the guy who stuck in a amd 3400 what was batt life Could someone detail the upgrade process? Security, i dont trust people, doesnt seen to have a lock slot, can you still physically tie the $2000 red slab to something? Also I would like to know more about heat. How hot is "warm around hdd" Thanks, really interested at this laptop Last edited by ntrekie; 06-17-2004 at 08:19 PM. Reason: more Q's |
#74 |
Credits: -343
ntrekie, dunno where you read that it doesn't have a lock slot, but it definitely does. its on the left back corner. haven't used it, but i can at least verify its existence heheh.
#75 |
Credits: 308
hey what kind of notebook locks do u guys recommend for this laptop?
| Tach's Acer Ferrari 3200 review | Tachnyrus | Acer Notebook Reviews | 14 | 01-23-2005 05:53 AM |
| X-bit labs review: Acer Ferrari 3200 and ASUS A4S00K: Let the Race Begin | snorre | Asus Notebooks | 12 | 01-23-2005 01:31 AM |
| Another Acer Ferrari 3200 Review | nikonx | Acer Notebook Reviews | 35 | 08-09-2004 09:01 AM |
| couple ferrari 3200 ?'s | sox2112 | Notebook Forums - General | 9 | 06-30-2004 05:54 PM |
| Need Advice - CyberPower S4-3200 vs. Acer Ferrari 3200 | KethalManden | Acer Notebooks | 42 | 06-01-2004 11:05 PM |
