#136 | |
Credits: -348
Ok, I'm still a newbe. I found the two screws marked <k> on the bottom (also tried removing all the others I could find underneath to no avail). After I remove the two <k> screws, where are these tabs, exactly? I would appreciate very detailed instructions. Just trying to add another 1 GB of RAM ... A drawing would be helpful! Thanks! Last edited by netjetter; 03-25-2007 at 10:15 PM. |
#137 | |
drum while you work
and here's what it looks like after you pop out the keyboard ![]() (image courtesy of member Flabby at z71 forums)
Notebook Forums Moderator & Administrator 590 bans and counting... |
#138 |
Credits: -348
Thank you. The manual I downloaded from the ASUS site didn't have any such pics. I'll give it a try and hope I don't break anything in the process!
#139 |
drum while you work
you can get the version with pictures here: http://www.z71forums.com/Downloads/Z71VInstallGuide.pdf
#140 |
Credits: -348
Cool! I got the manual and did the RAM install. I think I bent the tabs a bit, but everything seems to be working just fine. Thanks again!
(Why they don't just put the expansion slot under an easily removable cover in the bottom is beyond me ... |
#141 |
Credits: -339
Hi there
Got a problem with my Z71v - I think I fried my vid card. Is this the right place to post a help request? Basically, I was playing Prince of Persia and the system completely froze up (had to hard reset). When it restarted the Windows logo appeared, but there are weird vertical lines through the display. After the Windows logo the screen went blacl and wouldn't recover. I restarted in Safe mode and got into my desktop, and after fooling around a little I disabled the GeForce adapter. Now I can start up normally, but I am stuck with the graphics from Safe mode, and there are still lines in the display. Is there any way to replace the vid card if it is fried, or does it require a whole new motherboard? Is there somewhere I can buy the Mobo without replacing the whole unit? Thanks a lot |
#142 | |
drum while you work
#143 |
Credits: -348
Well, I'm not having a good year. My monitor has cracked and along several of the crack lines there is black (LCD fluid?) leaking under the screen. In the event it gets worse and I can no longer see anything on the monitor, what are my options for replacement? Anyone have an idea of cost, time, and/or suggested repair locations with contact numbers/email addresses? I'm in North Carolina, but bought mine via online order from a place in California (RJTech, I think). I'm looking for somewhere convenient and relatively reasonable in price vs. buying a whole new notebook.
Thanks. |
#144 |
Credits: -339
FYI - there are 3 or 4 Z71v LCD screens selling on Ebay for about $200 (plus shipping). I am NOT one of the sellers; just letting you know
#145 |
Credits: -348
Hi guys, I remember solving this problem before, but I forgot how. My computer turns on automatically, it's something with the wireless, could someone help me out?
#146 | |
Credits: -339
#147 | |
Credits: -284
#148 |
Credits: -284
This site will replace your card for you but the price is STEEP.
http://www.geared2play.com/store/pro...ries/parts.htm |
#149 | |
Credits: -339
#150 | |
drum while you work
| *** Unofficial Super PI Benchmark Thread *** | smilepak | Notebook Forums - General | 20 | 07-12-2005 01:36 PM |
