Go Back   NotebookForums.com > Notebook Manufacturers > Asus Notebook Forums > Asus Notebooks
Thread Tools Display Modes
Old 07-17-2005, 11:38 PM   #1
smilepak
You've Been Modded!
Credits: 1,435
smilepak is a n00b, but everyone loves n00bs!
Are you using Windows XP?
Another way to get to it is go to your control panel. Click on System icon. Click on Device Manager.
In the list of all the devices, right click on the one with the display adapater and update it that way.
[Asus Z71v | Intel Pentium-M 1.7 (735) => Overclocked 2.26Ghz | 2 GB DDR2-533 Corsair]
[ SPK's Asus Z71V Review | Asus Z71V Unofficial Support Thread | SPK's Website | Photo Blog | Hotel Blog | SAP Blog ]
smilepak is offline   Reply With Quote
Old 07-18-2005, 08:28 AM   #2
NoMoreMrNiceGuy
Credits: -330
NoMoreMrNiceGuy is a n00b, but everyone loves n00bs!
Yes, XP Pro. I'll check the CP route when I get off work this p.m. Thanks.
Norm
THE Music
NoMoreMrNiceGuy is offline   Reply With Quote
Old 07-18-2005, 07:15 PM   #3
NoMoreMrNiceGuy
Credits: -330
I checked. The reason I didn't have the same option you described in Step 10 was that I had not loaded ANY display drivers. I was going to just load the latest. That doesn't work. First I had to load those off the setup CD. Sorry for the confusion. Oh, and not haveing loaded the CD driver was the cause of my dodgy scrolling and window dragging. Sorry about the wild goose chase.
I think I can successfuly load the latest drivers now. Thanks!
Norm
THE Music
Old 07-18-2005, 08:05 PM   #4
smilepak
You've Been Modded!
Credits: 1,435
Ah, if you have not load any display drivers yet, then going to the control panel method will work for you.
Old 07-19-2005, 10:46 PM   #5
smilepak
You've Been Modded!
Credits: 1,435
Control Panel
System
Drive Manager
Click on Display Adapter and go in to the properties there...there is a button to uninstall driver.
Old 07-20-2005, 07:11 AM   #6
Passion
Credits: -346
Passion is a n00b, but everyone loves n00bs!
thanks, i hope it'll work. Before I just installed the driver 77.72 from the 77.50 without uninstalling 77.50 first, and I was still encountering the same problem.
btw, could it be that my video card is overheating?
Passion is offline   Reply With Quote
Old 08-02-2005, 12:41 PM   #7
smilepak
You've Been Modded!
Credits: 1,435
Official NVIDIA GO 6600 Website
http://www.nvidia.com/page/go_6600.html
Memory Interface 128-bit
Memory Bandwidth (GBps) 11.2 GBps
Fill Rate (pixels/sec.) 3 billion
Vertices/Second 300 million
RAMDACs 400 MHz
nVidia GO 6600 GPU Performance Test
*Note:
* All test based upon Asus Z71V nVidia GO 6600
* Asus Z71V STOCK SETTING IS: 250/500
* Toshiba used GO 6600 TC, which is slower
than one used in Asus Z71V
nVidia Driver v71.13
* Asus Stocked Video Driver
3DMark05: 1720 (250/500 Stocked Setting)
3DMark05: 2018 (275/563)
nVidia Driver v77.77
Driver: http://download.laptopvideo2go.com/drivers/7777.exe
INF: http://laptopvideo2go.com/infs/7777inf/nv4_disp.inf
Triple Buffer: http://www.notebookforums.com/showthread.php?t=99001
3DMark05: 1816 (250/500 stocked) -> Triple Buffering DISABLED
3DMark05: 1835 (250/500 stocked) -> Triple Buffering ENABLED
3DMark05: 2156 (290/575 stocked) -> Triple Buffering ENABLED
3DMark05: 2236 (300/600 stocked) -> Triple Buffering ENABLED
* Note: It seems to be with this new release of the nvidia driver, the modification of
adding the triple buffer improved performance! Actual result of course will vary on each machine.
OLDER VERSION OF NVIDIA DRIVERS
Using XtremeG nVidia Driver v71.84
3DMark05: 1780 (Stocked Setting)
3DMark05: 1970 (300 Core / 500 Memory)
By CMYK (his Asus Z71v - Driver: v76.44)
3DMark05: 1787 (Stocked Setting)
nVidia 77.30
3DMark05: 1813 (stocked setting)
3DMark05: 2060 (300 Core / 500 Memory)
nvidia 77.50
3DMark05: 1820 (stocked setting)
3DMark05: 2060 (300/500 OC Setting)
nVidia 77.62
3DMark05: 2055 (300/500 OC Setting)
3DMark05: 2120 (290/575 OC Setting)
XG 77.62-HD Type 2 nVidia Driver v77.62
3DMark05: 1820 (Stocked Setting)
3DMark05: 2074 (300/500 OC Setting)
3DMark05: 2169 (290/575 OC Setting)
3DMark05: 2215 (300/600 OC Setting)
nVidia 77.72 Official WHQL Release
3DMark05: 2069 (300/500 OC Setting)
3DMark05: 2223 (300/600 OC Setting)
nVidia 80.40 Beta Leaked
* AA OFF, Resolution 1024x768
3DMark05: 1821 (250/500 stocked setting)
3DMark05: 2121 (290/575 OC Setting)
3DMark05: 2236 (300/600 OC Setting)
* AA 2x, Resolution 1024x768
3DMark05: 1813 (250/500 stocked setting)
3DMark05: 1975 (290/575 OC Setting)
3DMark05: 2072 (300/600 OC Setting)
* AA 4x, Resolution 1024x768
3DMark05: 1523 (250/500 stocked setting)
3DMark05: 1733 (290/575 OC Setting)
3DMark05: 1817 (300/600 OC Setting)
WHERE TO GET NVIDIA DRIVERS
* http://forums.guru3d.com
* http://www.laptopvideo2go.com/forums/
* http://www.nvidia.com
How To Install
1) Download the nvidia driver
2) Extract it to a directory
3a) download the latest INF file from http://www.laptopvideo2go.com/forum/ and save it
to the same directory you had extracted earlier.
-OR-
3b) Use the NVAM.INF file that came with the original Asus Z71V display driver. You could download
it from http://support.asus.com and extract out the NVAM.INF from there.
4) Right click on the desktop and go to properties. This will take you
to the display control panel.
5) Click on the settings tab
6) Click on Advanced button
7) Click on Adapter tab
8) Click on Properties button
9) Click on Driver tab
10) Click on Update Driver button
11) Click on "No, Not this time" when asked "Can Windows Connect To Windows Update..."
12) Click on "Install from a list or specific location"
13) Click on "Don't Search, I will choose the driver to install"
14) Click on "Have Disk"
15) Browse to the location where you had saved the INF file earlier
16) Select the video card from the list, in Asus Z71V case it is nVidia GeForce Go 6600
17) Continue with install...
*USE AT YOUR OWN RISK!*
Old 09-17-2005, 04:43 PM   #8
Petr Mares
Petr Mares is a n00b, but everyone loves n00bs!
refresh Z71V?
Hi
I need help, don't you know anything about possible refresh Z71V? Especially that Express Card Slot or integrated BT? Thanks in advance
pm
Petr Mares is offline   Reply With Quote
Old 09-24-2005, 04:45 PM   #9
Cook1
Credits: -248
Cook1 is a n00b, but everyone loves n00bs!
Hey guys, first off having driver issues, posted in the general section instead. Sorry about that.
Secondly having a wierd thing with the keyboard. When I press Shift + 2 I am expecting the at symbol but what I really get is " and when I press Shift + " I am really getting the @ symbol. So basically my two keys are switched somehow. Anyone know anything about this?
Dell Inspiron | 9300
Pentium M 2.26GHz
7800GTX 256MB @ 445/1250
2GB DDR2 533
100GB 7200RPM HD
8x DL DVD+-RW
Samsung Truelife 17" 1920x1200 monitor
3DMark05 7455 | 3DMark06 3881
Cook1 is offline   Reply With Quote
Old 09-24-2005, 06:01 PM   #10
Tecknikal
Credits: -326
Tecknikal is a n00b, but everyone loves n00bs!
French keyboard !
ASUS Z71V
Intel® Pentium® M 1.6 GHz -2MB- 533FSB
1GB DDR2 533
Futjistu SATA 60GB 5400RPM 8MB Cache
Intel Wireless 2915 - 802.11A/B/G.
GeForce Go6600 128MB DDR
Tecknikal is offline   Reply With Quote
Old 09-24-2005, 07:08 PM   #11
Cook1
Credits: -248
That would explain why I get £ when I hit Shift + 3 but all the other keys are the same. But if it's a French Keyboard, why doesn't it have the £ symbol above the 3 instead of the pound symbol?
Pentium M 2.26GHz
2GB DDR2 533
100GB 7200RPM HD
8x DL DVD+-RW
Old 11-24-2005, 10:58 PM   #12
smilepak
You've Been Modded!
Credits: 1,435
New BIOS Release 11/21!!!
http://dlsvr03.asus.com/pub/ASUS/nb/Z71V/Z71V0210g.zip
BIOS Ver.0210G
1. Support Brazilian Keyboard
2. Update Intel VBIOS to 1224.
As well as update to ATK0100 Utility
http://dlsvr03.asus.com/pub/ASUS/nb/..._2K_051122.zip
Old 12-03-2005, 12:26 PM   #13
Djembe
drum while you work
Djembe's Avatar
Credits: 138,903
Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!Djembe has mad Admin skills!
Nvidia 82.04 drivers provided by ASUS: no modified INF required!
http://www.laptopvideo2go.com/forum/...showtopic=8221
Notebook Forums Moderator & Administrator
590 bans and counting...
Djembe is offline   Reply With Quote
Old 02-27-2006, 02:06 PM   #14
Ormsfang
Credits: -348
Ormsfang is a n00b, but everyone loves n00bs!
Just built mine
Just built my Z71V last week. Must say I am very impressed with this machibne. It games well, and I also use it to perform Nessus security scans (am a network security major). This means I am running windows xp, vmware, and running a nessus server in VMWARE on the same machine! This laptop does it very well!
Here are the specs:
Intel Pentium 760
2 Gig DDR2 533
80 GiG SATA Hdd
Internal a/b/g wireless
Total cost was under $1700 at http://www.directron.com
So far no real problems, no real worries.
Ormsfang is offline   Reply With Quote
Old 03-09-2006, 04:05 PM   #15
KennyS
KennyS is a n00b, but everyone loves n00bs!
Is the Z71 Linux compatible
I was just on the phone with ASUS support and they told me there is no support for Linux on the Z71. What distros of Linux work on the Z71? I've been trying to install Fedora core 4 and I can't get past the install screen when I get a kill kernal message - not syncing kill init. Has anyone else had any trouble or success with installing Linux OSs?
Kenny
kschork@gmail.com
KennyS is offline   Reply With Quote
*** Unofficial Super PI Benchmark Thread *** smilepak Notebook Forums - General 20 07-12-2005 01:36 PM
