#1 |
Well Iam still trying the only thing I can think of is that when I install QP 2.3 it turns the c drive into a d drive and the QP drive into a c drive? Can anyone help me? (please)
#2 | |
Credits: 288
Been there done that I used a linux recovery disk to change partition numbers but in all honesty a reinstall worked better. |
#3 | |
I have tryed to reinstall windows but the QPDP partition is set to c:\? If I format and reinstall I end up back to square one? Any hints as to what to do would be great! Thanks |
#4 |
Credits: -140
Has anyone tried installing XP Embed and Quickplay Seperatly. I Have a TX1000 and as you might expect I get the BSOD. I'm going to try two separate installs and keep you posted
#5 |
Credits: 12
Thx men 4 nice thread. But QP Direct is working in my DV2100 with the only 1 partition (I means C: only). One more matter is that in QP Direct, when I click windows flag, it does not change into full load XP, it cannot be turn off and I have to keep power button pressed for some while.
I do think that QP Direct is not so usefull but much trouble and decide not to use it. |
#6 |
Credits: 230
Hi i'm new a have one question
quickplay 2.3 direct works on vista?? if i do that what is on 44 page it will worked?? sory for ma english ok i see itr works i will be test Last edited by select1; 04-15-2008 at 01:14 PM. |
#7 |
Credits: 220
hello before begin Im thank's for all in this forum my dv6000 with xp have Quick Play 2.3 and it is work's OK. But in QP doesn,t work's my WebCam. In xp WebCam work's OK. What is problem?? Sorry for my English.
#8 |
Credits: 220
hi plsss help me about my quickplay 2.3 direct id work it about a week.... i have 3 partion all of my my parrtition is set to a primary partion and also i follow d intruction not to format the f: leave it raw....
![]() then i extract the hpqpdp and qwq in c swsetup....... then when i install the setup of hpqpd,, then when it goes to setup status it will hang at 15% and msg box Appear and contain ![]() the here is my loptop spec... hp dv6000 ihave windows xp media center ![]() |
#9 |
try this, it reported the same issues as you have
http://andreineculau.wordpress.com/2...23-re-install/ cheers ...
m6805@3700; SZ71WN/C ; Macbook 2ghz/4gig/250gb/superdrive; 7811FX are u Folding@Home? - Firefox Beta - MediaPortal "the" Media Centre/HTPC! |
#10 |
Credits: -310
hey folks;
I have a big Problem... I try 1 million times install the HP quickplay direct and all times i have a message BSOD. My notebook is a new DV5-1004nr... Any one have a good experience on this model? Thanks for help... |
#11 |
Credits: 221
Hello ,
i'm new here. i have a problem about Quickplay direct 2.3 installation. after format i install window XP then drivers. i shrink my partion and leaving 1027.6 MB UNALLOCATED space. then i extrack HPQPDP to c:\SwSetup\HPQPDP folder and run setup.exe. but when it say it need to reboot my window >> i click yes >> when it reboot my window can't reboot again it always got blue screen . can anyone tell me how to fix this? plss i'm using dv2000(dv2102TU). sorry for my english. Last edited by geminus; 06-23-2009 at 02:34 AM. |
#12 |
Credits: 221
anyone help pls
#13 |
Have you read the whole thread and see if there are some tips?
| Quickplay 2.1 & Quickplay 2.1 Direct??? | Bracholi | HP, Compaq and Voodoo Notebooks | 39 | 10-16-2006 01:54 AM |
| Disable quickplay | acruz | HP, Compaq and Voodoo Notebooks | 1 | 08-19-2006 03:52 PM |
| what's Quickplay? | tonyha | HP, Compaq and Voodoo Notebooks | 3 | 07-16-2006 10:59 AM |
| Want something like HP's QuickPlay or Intervideo InstantOn | lordsavant | HP, Compaq and Voodoo Notebooks | 0 | 08-30-2005 02:30 PM |
