#1 |
Credits: -32
HOW-TO: Upgrade your 9400/E1705 with the 512MB 7900 GTX "Photo Guide"
Hi all everyone has been asking for it so here it is!
How to get a 7900GTX in a Dell 9400, (I take no responsibility for damaging your laptop! do it at your own risk!) Step 1 Load new A01 9400/E1705 Bios onto the laptop Step 2 Remove Screen/Keyboard/palm rest from the laptop. Step 2 Remove the original video card. Step 3 Remove metal from above CPU heatsink area. ![]() The left side needs more removing than the right side, I used some pliers to break off the edges. but a dremel may be better Should be link this Step 4 Fit new 7900gtx inplace and screw in ![]() Step 6 Fit laptop back together, you should have a working system! Have also confirmed you do need the XPS 130W power adapter, as the 90W dies when graphics card it at full power. also 9 cell battery as it will not last long on a 6 Cell Hope you all find this helpfull!
Inspiron 9400|Core Duo T2600|NVIDIA GeForce Go 512MB 7900 GTX[606MHz/725MHz]|1GB DDR2 PC5300|17" WUXGA|100GB 7200RPM|8×DVD±RW|802.11a/b/g| |3DMark05:9871| |3DMark06:5658| Last edited by Steve; 04-30-2008 at 12:06 PM. |
#2 |
Credits: -326
Nice job! Can't wait for the 7900 GTX to be available as a spare part!
#3 |
Great! Thanks for the write-up
Latest Laptop: Inspiron E1705 | T2600 (2.16GHz/667MHz FSB) | 17 inch UltraSharp™ LCD with TrueLife™ | 2GB DDR2 at 667MHz | 512MB NVIDA® GeForce™ Go 7950GTX
#4 |
This needs a sticky...
"Don't take life too seriously. No one gets out alive anyway." |
#5 |
Credits: -32
how do you get a sticky, up to the mods?
Inspiron 9400|Core Duo T2600|NVIDIA GeForce Go 512MB 7900 GTX[606MHz/725MHz]|1GB DDR2 PC5300|17" WUXGA|100GB 7200RPM|8×DVD±RW|802.11a/b/g| |3DMark05:9871| |3DMark06:5658| |
#6 |
Awesome thread, here's some well deserved rep
Current: Inspiron 700M: 1.8 Ghz - 768MB RAM - 80 GB HD - Atheros CM-9 A/B/G - XP Pro Previous: Inspiron 9400 - SOLD Previous: Inspiron 9100 - SOLD |
#7 |
Purveyor of fine soaps
Credits: -38
It's amusing that after the whole 9300 upgrade, Dell made it even EASIER to put a 7900 GTX into the 9400.
Once proud owner of a 9300. Now without any mobile computing power at all. Sigh. 9300 to XPS 2 Bios Flash (For 6800 Ultra/7800GTX) | TrueVolt utility for pinmodding |
#8 |
Credits: -270
Is the 9 cell battery required or recommended. I have a 1705 in the TESTING stage now that I got for about $1200 but I ordered it with the 6 cell because I will use it 95% of the time on ac power. Please let me know so I can cancel it if I have to and re-order it with the 9cell. Also can I get the 1705 shipped with the 130 watt power supply if I call them?
#9 |
Credits: -32
it will work with 6 cell, but won't last that long, still need the bigger 130w psu, not the standard 9400.
#10 | |
Credits: -270
#11 |
Credits: -38
if you don't have it on battery, it won't matter.
#12 |
ya, i NEVER use my xps gen-2 on battery, so i don't care about the battery... just, you can't order the e1705 with a 130w adapter, can you?
Dell Inspiron XPS Gen-2: 2.13ghz Centrino 770/ WUXGA 1920x1200 17"/ 7800 GO GTX @ 440Mhz Clock & 1230Mhz Memory/ 2GB RAM/ 60 GB 7200 RPM ATA Hitachi HDD/ Undervolted @.716V with x6/ @1.132V with x16 (bad undervolter )/ 3dMark06: 445Mhz/1230Mhz, 1280x1024: 3900 (1795/1784/904)
#13 | |
Credits: -270
#14 |
Nice job mbosys.
OK bad news for the 9300/XPS2/M170 owners. Looks like the 7900 GTX will not fit into our mobo. Here's a pic of mbosys's 9400 with the 7900GTX and my 9300 with the 7800GTX. See where the red circle is, big problem.
Inspiron 9300 Pentium-M 1.6 pinmodded --> 2.13 GHz (1.22 volts) 2 GB Transcend Samsung chips RAM GeForce Go 7800 GTX @445/1250 80 GB HDD 17" WUXGA TrueLife. |
#15 |
Where exactly did you use pliers and break on the left side? I can't tell from the picture.
Dell M1710: T2400 (1.83 GHz) [Soon to be C2D T7200] | 512 MB 7900 Go GTX | 17" WUXGA (gorgeous LG display)|2 GB DDR 2 (667 Mushkin) | 100 GB HD 7.2K (Hitachi) | 8x dvd burner (Toshiba) | 3 yrs warranty + nights/weekends MacBook Pro:2.33GHz Intel Core 2 Duo | 2GB 667 DDR2 SDRAM-2x1GB | ATi X1600 256 MB GPU | 120GB Serial ATA Drive@5400rpm | SuperDrive 6X | 15" Glossy Widescreen Display ![]() CLICK FOR MY HEATWARE! |
Previous Thread
Next Thread
| How To Upgrade your 9400/E1705 with the 7800 GTX "Photo Guide" | mbosys | Dell Home (Inspiron, XPS, Studio) | 45 | 12-25-2006 02:23 AM |
| Soon 7900 GS is coming to 9400 / e1705 | solvexyz | Dell Home (Inspiron, XPS, Studio) | 31 | 05-13-2006 10:56 PM |
| Who's waiting for the 7900 GS for E1705/9400? | Wingatebyebye | Dell Home (Inspiron, XPS, Studio) | 6 | 04-26-2006 09:21 AM |
Linear Mode
