#1 |
Step-By-Step Adding a Second Hard Drive to an 8886/8887
STEP 1: Gather everthing you'll need: Computer, New Hard Drive in the proper bracket, 2 Phillips screw drivers (small & smaller). Making sure the laptop is OFF, flip it upside down and locate the panel to the TV-Tuner compartment (three screws). STEP 2: Unscrew the compartment lid and place to the side. STEP 3: Locate the single TINY screw and carefully unscrew it (you can see that mine ended up being broken from over-tightening, probably when it was re-assembled after painting). STEP 4: Once the screw is removed, slide the empty bay holder out by pulling straight and evenly. If you DO NOT have a custom paint job (and do not need to swap brackets, skip to STEP X below). STEP 5: Lay the two trays side-by-side: notice anything? YES! They ARE the same! STEP 6: Here we unscrew (4 screws) the blank plate from the empty, painted bracket... STEP 7: Remove the new HD from the new bracket (4 screws) as well as unscrew (very carefully) the two SMALL screws on the IC board. STEP 8: Install the new HD in the painted bracket (and vice-versa for the blank plate, just to it's less pieces floating around). STEP 9: Slide the drive/bracket back in carefully, straight and easy. You may have to tuck the orange translucent ribbon thing under, but it does slide and click (slight click). Screw the tab in (I repaired mine with superglue). Put the cover back on the TV-Tuner bay and re-screw the three screws. You're DONE! Boot into BIOS just to see your second HD (oddly enough, it shows up as Hard Drive F). How's THAT for a Laptop BIOS screen? Sure, it could say FOUR 60GB drives (or those new 80GB ones that www.pctorque.com has up, but I have 60's and they're both 5400rpm!) PM me if you have any questions (or reply here). -myrkat
Infinite Rider on the Big Dogma • Support the Mozilla Foundation 8887-X • 1GB RAM • 3.o6GHz-HT • DUAL 6oGB/54oo • DVD/CDRW • mp3 • TV-Tuner • Hybrid—Color • 16.1" UXGA —Pictures for the curious— † —Adding a second drive— † ...this sig for rent or theft... |
#2 |
Still working on that funky bedspread, eh Myrkat? It does go well with that red laptop! Nice review. It would lead one to believe that if you bought the 8887 with the 2nd bay empty, you already have the $30 bracket for a hard drive. Interesting to note that the PC Torque customize laptop options list the 80GB as 4200RPM but the Accessories page lists it as a 5400RPM. Probably an error on Accessories. For the time being I'm filling my 60GB while I wait for 7200RPM.
(May2007): Dell Lat. D420 (Da' spare lappie rvw) (May2006): Dell XPS M1710 T7600 (2.33GHz/667Mhz), 4GB RAM, 512MB NVIDIA GeForce Go 7900 GTX, 80GB@7200, 8XDVD+/-RW, 17" WUXGA M1710 Review vs. Acer 8104 D/Dock, Pers Shield rvw (Jan2005-Jun2006): Acer TM 8104 2.0Ghz, 2GB, ATI X700 128MB 8104 review, Acer ezDock review (Feb2003-Jan2005): Sager 8887X |
#3 |
The 80GB is only 4200rpm; and the Bracket also has the IC bridge thing to connect the drive to the laptop (yeah, I thought the same thing at first, like: why did I buy a $30 bracket that's now sitting on my shelf?).
Yeah, that's the bedspread alright. Wife loves it. Had I received the drive a few weeks ago, it would have been on the "white" side (it's double-sided), as luck has it, it was back on the "orangish" side. So now I have a precedent: all photo reviews are to be shot on the orangish side. ![]() -myrkat
#4 |
Credits: -44
Is there anywhere you get laptop hard drives besides sager?
Sager 8887 w/ great 16.1" P4 2.4ghz MR9000 128 256mb RAM (will be 768 asap) |
#5 |
Credits: -298
pricewatch.com
_______________ Davkenrem 5660V==>now 5690V |
#6 |
what size is that 80gb for the 8887, and can i purchase the bracket sans drive...
#7 | |
You can pick up 2.5" HD's most anywhere, but the larger 5400rpm drives are not easily (or readily) found, most places are back-ordered. Haven't seen the 80GB/4200rpm drives yet. -myrkat
#8 | |
#9 | |
Credits: -347
regarding swap
Not to be picky.... But where is STEP X? It is cold in the scriptorium, my thumb aches. I leave this manuscript, I do not know for whom; I no longer know what it is about: stat rosa pristina nomine, nomina nuda tenemus. |
#10 |
Picky, picky, picky. I think Myrkat's out of town, but if you're not swapping drive brackets I think he means the next step after that process, which looks like Step 9.
#11 |
Credits: -347
I really like the response time on these replies.
Thanxs for the update MrMsyvc!
It is cold in the scriptorium, my thumb aches. I leave this manuscript, I do not know for whom; I no longer know what it is about: stat rosa pristina nomine, nomina nuda tenemus |
#12 | |
-myrkat
#13 |
Show off. Good work!
#14 |
Yeah, it's been a cool trip so far; the kids have been GREAT considering the 12-hour+ flight and the 7-hour (in my 5th hour) layover.
Another side-benefit is, I bought a (version 1) 20GB Windows iPOD for the trip and my wife used it for 10 minutes when she leaned over and said, "I want one!" then simply said "Thank You!" - I told her I'd get her one of her very own (the newer sleeker ones, maybe a 10GB) when we get back stateside. That and the Nokia 6310i I picked up duty-free (they have like a 20% tax here! Jeeze! I know I can get it back w/ paperwork, but the duty-free stuff is instant). -myrkat
#15 |
Heh, funny enough, the forum has this post at my local time of 9:13 a.m. when it's 6:13p.m. here... oh well, I think dynamic time/session variables are not going to be anything we see soon.
-myrkat
| adding hard drive | greddy | Alienware Area-51 and Aurora Notebooks | 0 | 05-19-2006 07:13 PM |
| Adding a hard drive | slapthemonkey55 | Alienware General | 5 | 12-13-2004 03:46 PM |
| Adding a Third Hard Drive | Rakewell | Sager 88XX Tech Support (Tech problems only) | 13 | 07-30-2004 11:44 AM |
| Adding a 2nd Hard drive | DarphBobo | Sager 88XX Tech Support (Tech problems only) | 10 | 12-04-2003 05:28 AM |
| Adding a Hard Drive | Michael | Sager & Clevo Notebooks | 2 | 02-14-2003 12:25 PM |
