9880 Cooling
post #1 of 11
Hey everyone. I just got a 9880 and am loving everyminute of it. I got 2 beefs with it. 1st off. ITS FREAKING HOT. Burn my finger hot, i kid you not. Next, one of my fans on the back right seems to work intermitantly (sp?).
My question is: I was looking into "laptop" coolers and saw the Targus Tornado Chill Matâ„¢ (PA248U) in Circuit City. It seems to have gotten good reviews. Is this a good cooler to get for this computer? If not, is there another one that someone could recommend? Also, i noticed that some, if not all, of the fans on teh bottom blow in, not out. Would these coolers mess the airflow up?
Thanks for any advice/recommendations guys/gals. Cheers!
Carpe Jugulum!
post #2 of 11
press Fn + F2
post #3 of 11
??? say what? My f2 key has nothing on it. What will that do?
post #4 of 11
It throttles your fans into "high mode" for additional cooling.
post #5 of 11
Hey thanks! It'll throttle even thought there is no writing on the key?
Also, to my orginal question. Anyone use a notebook cooler for their Sagers (9880)? How about that Targus mentioned before?
post #6 of 11
Try the lapinator at http://www.lapinator.com/
it hasnt got any fans but it keeps you from hot i use one, there very good
post #7 of 11
This is the best laptop cooling method so far:
http://www.notebookforums.com/showth...94#post1201694
post #8 of 11
Suhweet!!!!
Both of those are just what i was looking for. My sager is too big to fit on a dinner tray table, so that tray is ideal. Those Feet are perfect, since my laptop sits too low anyway. Thanks to both of you for the suggestions.
Semper Fi
Carpe Jugulum!
Best time to kick a man is when he's down.
post #9 of 11
Just an update. I tried pushing fn/f2 and nothing is happining. I was reading something about the ability being available in the newest bios version. Do i have that? i'm running 10.0.04 or something like that. if i don't, then where can i get it or which one is it. I looked on Sager's site for driver downloads but there is only the same bios version posted
Semper
post #10 of 11
The new bios is under the old one on sager site.
post #11 of 11
i got it. Thanks. I must be blind. Thanks for the post.
