Im looking into getting one. My problem is Im using a Athlon 2600/9600-XT rig so I wont really be able to run any high end current games in its native resolution. I do want one just as a monitor replacment and since it has component inputs use it for upcoming consoles like the Xbox 360.
Does it only support its native resolution or can I run it in lower resolutions although I probably will have a bit of a quality loss?
