Im looking for a new notebook, but im confused between the 710m and the 640m/e1405
which one do you all suggest?
what is the size/weight difference between the two?. is the 710m really portable?
also will the processing power difference between the two be noticible?
also which one would give a better battery life?
thanks
thanks
