9100 help!
post #1 of 10
My 9100 was gradually running slower, it had been switched on for a few days so I simply thought it needed a restart. I rebooted and it was still running excessively slowley, as if the CPU had thermal throttling running.
I took the machine apart, and vacumed it all, as I have in the past, except this time I vacumed the heatsink directly over the CPU, which was completly clogged with dust.
I put everything back together uneventfully, and booted, immediatly all the fans spun up to maximum, before it even got through post. Now it is running fine, but the CPU temperature reports to be 85C (the max the I8Kfan monitor goes up to, and all other temperature monitors (except harddrive) report null).
Throughtout the whole cleaning part I was very careful, and I have worked on many computers in the past so i doubt I could have damaged it in any way, also it was doing something similar to what it is doing now before I took it apart, however could it be a possibility that I damaged the temperature sensors?
Where are the temperature sensors? as in all of them, ie the CPU, chipset, the graphics card and Dimm sensors, are they on the respective boards themselves or near the heatsinks?
What do you reccommend I do, I am using the computer now to type this, so it does work in a sense, but it's rediculiously slow.
Can I disable CPU thermal throttleing?
Would flashing the BIOS help? (if so where can I get a new bios and flash program?)
Should I call dell? (I am out of warranty though)
Any help is really really appreciated, even as I am typing this my once fast 9100 cannot keep up.
post #2 of 10
sounds like a software problem to me... but I dunno.
post #3 of 10
Why post for the sake of posting?
post #4 of 10
What BIOS version are you running?
http://support.dell.com/support/down...&os=WW1&osl=EN
the link above has some drivers for your Dell, but in turns of heat...yeah 85C is hella high! I would tell you to try and use AS5 (Artic Silver 5) and reapply the thermal paste to your CPU and GPU, but you may be beyond that point. Best best, check your BIOS as make sure your running the latest, and check your video card drivers as well... that *may* help... if that doesnt work I'd probably call dell (or chat online with support). There are some threads here that have had people similar problems.
Hope this helps
this thread had people who had similar problems and where able to get their laptops replaced:
http://www.notebookforums.com/thread156992.html
post #5 of 10
If I didn't think it was a software problem, I wouldn't have posted.
post #6 of 10
As an idea....try the windows task manager. Check processes....spoolsv.exe can be a hog. I know not why :-)
Instant fix if that is the case is to right click and end process. If that is the problem check the printer folder to see if the Window document Image writer has anything queued.
My 9100 had this problem.
post #7 of 10
As soon as I turn it on the fans spin up, during post. It's not a software problem unless it's a bios problem.
Thanks Trekkminster, reading that link.
post #8 of 10
Well, first thing would be to ensure you have the latest bios !! Can't tell you which that is as I am work. just go to Dell website and find it... Which I know sometimes can be easier said then done!!!
Bob
post #9 of 10
same with you. dont like a reply, dont read or respond to it. this is a non-paid board. you get what you pay for. actually we get a whole lot more than we pay for here. but not every single reply is going to cater to you. let it slide.
post #10 of 10
if you have A03 bios you can press Fn+Z to reduce the speed of the fans to normal.it was well known problem with i8fangui.By pressing Fn+Z you are telling the bios to take over i8fangui and don't worry the cpu temperature isn't 85C if you have A03 bios you can press Fn+Z+R and you will be able to see bios temperature readings
