2500M -> 7950GTX possible?
post #1 of 12
Well, I know it's possible to have my 2500M flashed to the 7900GTX. However, I was wondering if I could flash it to the 7950GTX. If possible, would I get the same performance as native 7950GTX since people are saying that the only difference between the cards are clock speeds?!
Also, I have 4GB of RAM, should I use the "memory optimized" option when flashing or not? Why/why not?
Thanks in advance...
post #2 of 12
Cmon guys... someone please reply. I want some feedback before blowing my laptop up.
post #3 of 12
Uhmm, why? The 2500M is identical, performance-wise, to the 7900GTX, so why would you want to flash it? Also, I believe the "unlocked video BIOS" thread (sticky) has an unlocked BIOS for the 2500M, which should allow you to overclock it to your heart's desire.
post #4 of 12
I know that the 2500 is identical to the 7900GTX, but unfortunately the drivers aren't realeased for it nearly as often. I have been using LV2Go's and X-treme G's without a problem, but folks told me I could get slightly better performance from the 7900GTX.
So I was wondering if having it flashed to the 7950GTX would yield even better performance. Hence my question of whether it is possible or not.
I have my 2500M unlocked already, I was just wondering if I should use the "memory optimized" BIOS with my 4GB of RAM or not. I hear it can conflict when overclocking.
post #5 of 12
They are full of it, the FX2500 is the EXACT SAME CHIP with a different BIOS is all. Using 3rd party drivers does alleviate infrequent updates. (Mind you though 90% of Quadro users are developers and not gamers, stability is more important to them than the few extra FPS a driver update might deliver)
No, you won't see any performance gain worth the effort. Your synthetic benchmark scores might go up a few points but you won't see any real world difference.
post #6 of 12
Hmmm, that sucks. I guess I was just asking because I have been getting some weird performance with some games. I feel like my laptop isn't performing as well as it should. I get really low performance playing HL1 mods and better performance playing later games, etc. I don't understand why that would be the case.
post #7 of 12
what are your current 3Dmark05/06 scores right now?
post #8 of 12
I am getting about 8200s in 3dMark05. Which doesn't seem that far off from what others are getting. But my gaming experiences doesn't seem to be on par with others. Also, I can't seem to be able to overclock my video card. Whenever I increase the clock speeds, even if slightly, my 3dMark05 drops significantly. I don't understand what the problem is.
post #9 of 12
Are you running Halflife 1 in D3D or Open GL? If memory serves me correctly the OpenGL renderer has better performance than the Direct 3D one.
post #10 of 12
You should be getting around 4700 to 4780 in 3DMark06 depending on your CPU speed.
The 7950 can be clocked somewhat higher than the 7900GTX/2500M but Dell does not clock it much higher. But, if you use OpenGL, the 2500M and 3500M are better performing and have better quality (eg antialiased wireframes and gamma-corrected antialiasing). The DirectX performance is about the same, within 2% of what a 7900gtx would get, for the 2500M. Which makes sense as its the same core.
I have heard that flashing a 2500M to 7950 or 3500 will get you a black screen, so urge caution there.
post #11 of 12
7950GTX and 3500M have higher Memory voltages.
the 7900gtx and 2500m won't be able to run those voltages. Best way is just to overclock the frequencies.
post #12 of 12
Interesting, didn't know that. Care to elaborate? I know the 2500M (and 7900GTX) have two voltages, 1V and 1.24V, but whether that is applied to the core or the memory I don't know.
