NotebookForums.com › Forums › Notebook Manufacturers › Gateway Notebook Forums › Gateway Notebooks › 6860FX upgrade to T7200, won't boot
6860FX upgrade to T7200, won't boot - Page 2
post #21 of 25
I have personally installed a T7300/T7500 and the T8300 into it. Best bang for the buck would be the T8300
post #22 of 25
Awesome. Thanks for that advice. I just found a cheap T7300 engineering sample up on fleabay. I think that'll get me by for a while.
post #23 of 25
And yes, the T7200/7400/7600 are not compatible.
any ideas as to what makes them non compatible?
post #24 of 25
Chipset won't support it (965) as opposed to the 945 (T7200...)
post #25 of 25
T7200 looks like a socket M CPU,
T5550 looks like a socket P CPU.
Maybe that's the problem.
I have a E1705, I just ordered a P6860FX.
