1526 boot issues
post #1 of 4
My inspiron 1526 turns powers on with no display then gives the code
Blinking, solid, solid
num , caps , scroll
The power light comes on and stays on, hdd light never comes on , dvd drive lights up
post #2 of 4
Try re-seating the memory
If you have two DIMMs try using one at a time and in each slot.
post #3 of 4
First thing I did was replace the mem and the hdd they are both working
post #4 of 4
it kind of leaves you with two aras
GPU or Motherboard
Have you tried an external monitor ?
Try booting up with a base config
no Drives, one memory DIMM, no wireless cards, no battery
Swap Memory positon and try again.
Try above with no AC, just the battery
