NotebookForums.com › Forums › Notebook Manufacturers › Acer Forums › Acer Notebooks › 5755g games problem when using battery
post #1 of 8
I have a problem with my acer 5755g when i playing games with battery the game performance is very bad and laggy...although it is able to choose whether use intel HD graphic or NVIDIA high performance graphic but both also laggy....but when i plugged in the power source the game works well and great....can anyone help me solve this problem?
post #2 of 8
Try first setting the power scheme the same when on power or on battery
post #3 of 8
i set the power option to high performance but the result came out also the same
post #4 of 8
The same setting for battery and external power?
post #5 of 8
i'm not sure all the setting same because i dunno every single place that need to set....but i did set high performance in my power option when using battery
post #6 of 8
Yes, it can be very tricky. Best thing is to go back to the power option, digging down to the advanced options, reviewing each and every single setting "when on battery", "what happens when the battery level drops to certain point" etc ... One entry can take precedent over others.
post #7 of 8
I have changed all the setting that related to performance exactly same as plugged in....jus some option that dim display , turn off display i leave it
post #8 of 8
Are there any game patches needed to apply?
  Back to Forum: Acer Notebooks
