I've had my M6809 for about two months now and have been experiencinga ll of the same problems you guys are [800Mhz on battery, two cracked hinges after one month usage] but I have recently come across a new flaw that just blows my mind. Wondering if anyone else is experiencing this. I use my notebook mostly for Pro Audio [audio production, mixing, etc.] so I use an MAudio Firewire 410 audio interface with it. This interface works fine with my desktop setup, and with many other laptops that I've tested [Toshiba, Sony Vaio], but when I plug it into the 6809 and plug the output to speakers or an amplifier, I get the most horrible digital / AC noise I have ever heard. I've tested this up and down to make sure it's not a grounding issue or a problem with my amp or wiring. I tested this with different amps, different audio interfaces [MOTU Firewire 828] and different laptops mentioned above. It comes down to one simple fact... when plugged into the AC adaptor, the 6809 makes this horrid noise through the Firewire Bus and into my amp... when you unplug the AC and run off battery, it's clean. I also tested this with my friend's 6805 and the same phenomenon occurs, so this is not just my firewire card or AC adaptor going bad. This is blowing my mind. I contacted eMachines about this problem and spent 50 minutes on the phone with a tech rep who would only say they will not support third party hardware... but wouldn't you say that when their computer produces that sound through any firewire audio interface I can find, that it's a little more than just a compatibility issue? I finally got the rep to admit that the problem probably lies in the AC converter card in the notebook, but they were unwilling to do anything about it except RMA the machine and check to make sure everything worked the way it left the factory. So, guess what I want to know is, anybody else have a problem like this? I know this exists for at least two notebooks... one 6809 and one 6805. If it's just these two, great, i'll return it and get a new one... but if not, WOW, what an enormously major hardware flaw. Please reply!
NotebookForums.com › Forums › Notebook Manufacturers › Gateway Notebook Forums › Gateway Notebooks › 6809 Firewire Problem
Recent Reviews
So I just got a Lenovo Yoga 13. This is my review. As what I primarily do is writing and programming, having a good keyboard is critical for me, which is why a tablet alone can’t work for me, and...
I have owned dozens of laptops in a variety of brands, and had many different laptops provided for my use at work. Without question, this is the finest I have owned. The Alienware M17x R2 is a...
N/m
Lenovo Thinkpad W530 Review by Djembe One of the longest and most enduring brands in computers is Thinkpad. Originally developed by IBM in the USA, Thinkpad notebook computers are now...
I have this memory installed in my Inspiron 14R. 6gb (one 2gb & one 4gb). Great performance! I highly recommend Kingston.
post #2 of 17
7/16/04 at 3:21pm
I would contact Arima, OEM, directly. There have been reported speed issues due to the chipset used with the 68xx firewire. Sounds like a ground loop problem. Anyway you could use a third party AC brick? I wonder if you could use an external Firewire Hub for ISO? Is the 4 to 6pin firewire cable to specs?
Let us know!
Let us know!
Good idea about Arima. Any idea what their contact info is? I'll google it here. Didn't know about the reported speed issues. As for the AC Brick, already tried it. I've run both the Audio Interface [which has it's own sepereate power supply] and the Notebook power supply through $400 power conditioners and different AC bricks and it didn't seem to make a difference. Also tried using a PCMIA card with 6pin firewire out on it and the same noise occured. It seems to be a bus problem throughout the machine. I'll check up with Arima and see what I can find.
Sent an e-mail to Arima detailing the problem. Wasn't exactly easy to find a way to contact them, so I used the only address I could find which was nb@arima.com.tw . Now gotta wait to see if they ever respond.
post #5 of 17
7/24/04 at 3:08pm
- Ultimatetone
- 0
- Registered User
- offline
- Select All Posts By This User
WOW!
I had been initially thinking about getting an eMachines M6809
...and now a M6811.
I also planned to use a M-Audio Firewire 410 interface as well!
I immediately thought 'ground loop issue' too, when I read the initial post here.
At this point in time, I am just going to have to keep researching other options.
I am lookin for (ideally, of course) the following attributes:
- AMD Athlon 64 3200 or better
- 15 inch WXGA Screen (at least)
- ATI 9600 (9700 is fine too, I'm not a gamer, so...)
- 512 MB RAM
- DVD-R/RW/+R/RW CD-R/RW Drive
- True USB 2.0 and Firewire ports (audio hardware friendly, of course)
- PCMCIA Card slot
- Built-in 802.11 G Wireless (nice)
- Built-in Bluetooth (would be nice, but...)
- Price tag under $1600.00
I am open to suggestions.
Good thing we have forum's like this one to help potential buyers
'suss-out' the quirks and support issues we may encounter.
Ultimatetone
...and now a M6811.
- 512 MB RAM
- PCMCIA Card slot
Ultimatetone
post #6 of 17
7/24/04 at 4:04pm
post #7 of 17
7/24/04 at 5:27pm
- Ultimatetone
- 0
- Registered User
- offline
Originally Posted by kooloser
The compaq would have everything you want except the video card...
I did recall looking at a HP (Compaq?) Notebook at Best Buy.com
with very similar features ...and a 'lesser' graphics card - like you stated.
I see that notebooks are still being labelled as HP or Compaq it seems.
I thought perhaps (by now) we would see just one name - either HP or Compaq.
Which Compaq Notebook model (in particular) were you referring to?
WOW -
While I was awaiting your reply -
I config'ed a Compaq R3000Z Series Notebook on their website
Specs -
Processor AMD Athlon(TM) 64 3400+ 2.20 GHz
Operating System Microsoft(R) Windows(R) XP Professional-only $49!!
Memory 512MB DDR SDRAM (1x512MB)
Hard Drive FREE Upgrade from 40GB to 60GB 4200 RPM Hard Drive
Primary CD/DVD Drive DVD/CDRW Combo Drive
54g(TM) Integ. Broadcom 802.11b/g WLAN & Bluetooth
Display 15.4" WVA WSXGA+ (1680x1050)
Graphics Card 64MB NVIDIA(R) GeForce(TM) 4 440 Go +1394 & 5-in-1 edit
Productivity Software Microsoft(R) Works/Money
Primary Battery 12 Cell Lithium Ion Battery
totalling only $1,466.00*
*After $30.00 mail in rebate
incl.FREE 5-7 day shipping (no tax to FL)
Ultimatetone
post #8 of 17
7/24/04 at 6:03pm
That would be the one I was thinking of...
The difference between HP and Compaq that I know is that Compaq is silver and HP is blue...meaning I would buy compaq first because for some reason their a bit cheaper still and silver looks better...The main reason for not destroying compaq would most likely be brand recognition, think car companies...
post #9 of 17
7/24/04 at 6:30pm
- Ultimatetone
- 0
- Registered User
- offline
I also config'ed the HP zv5000z series Notebook on their website -
60 GB 4200 RPM Hard Drive
Networking 54g(TM) Integ. Broadcom 802.11b/g WLAN & Bluetooth
totalling $1,676.00*
*After $50.00 mail in rebate
incl. FREE 5-7 day shipping (no tax to FL)
I guess the Compaq sure is the one to go with.
Ultimatetone
Ultimatetone
Possible Fix to the Firewire problem. I read through a ProTools forum earlier today with a post that had the same firewire problem I had except with a protools setup. They had lifted the ground of the AC brick on the laptop AND used balanced cables whenever connecting to the outputs of the audio interface and this worked for them. I checked with my setup and this seems to work as well. Guess part of it then does have to do with a ground loop issue. But balanced cables needed for an unbalanced ouput? Who would've thought? Oh well, it works now, so I'm happy.
post #11 of 17
8/1/04 at 3:52pm
| They had lifted the ground of the AC brick on the laptop AND used balanced cables whenever connecting to the outputs of the audio interface and this worked for them. |
Also using for live sound, so picture that AC static at ear bursting decibels
Anyway, could someone clue me in on what this solution was? Thanks.
Hey Gauge,
I've tested this and it does work with my laptop. To do it, just go out to Radio Shack and by a cheap little three prong to two prong adaptor to put on the plug of the AC brick for the laptop. The third prong is for grounding but also creates this problem if the grounding is not done right inside the laptop [gotta love e-machines]. This isn't the safest way to do it, however, since it can damage your hardware if there are dangerous AC levels or spikes. I'm told you can get rid of this noise as well if you connect your audio outputs with Balanced cables instead of regular unbalanced cables. XLR cables are balanced already, and you can get regular 1/4 inch cables [TRS] that are balanced as well. Again, I haven't tried this yet, but will in next couple days as it would be a much safer solution than lifting the ground. Hope that helps.
post #13 of 17
8/3/04 at 1:32pm
post #14 of 17
8/3/04 at 6:13pm
post #15 of 17
8/6/04 at 10:32pm
I think I have another twist to add to the noise.....
I too use my m6809 to record audio. Instead of using a firewire audio interface, I am using an Echo Indigo I/O. I too hear no noise when on batteries and a horrible buzz when using the AC power. During my troubleshooting phase I noticed this:The processor speed is directly related to the amount of noise!
I don;t know about the rest of you, but when my AC brick is used I have my power setting on "always on". This keeps the CPU at 2.0GHz. But when you unplug the AC brick it automatically drops it down to 800MHz. With this in mind, I adjusted the power settings while the AC brick was plugged in. Know what happened? When I set it for "Max Battery" the noise went down. I checked the CPU speed and it was down to 800MHz.
Unfortunately, I don't know how this information can help. All I have is the Belief that the processor speed is directly related to the audio noise.
Don't let anyone tell you it's your external hardware either! I get the same audio noise playing back waves files on Windows media player using the laptop's headphone jack.
Please post any info you guys find that can correct this problem.
If there is none, I might just keep exchanging M68xx models at Best Buy until I get one that works
Bummer,
GH
post #16 of 17
8/7/04 at 5:10am
Originally Posted by gypsyhick
The processor speed is directly related to the amount of noise! |
post #17 of 17
8/7/04 at 9:04am
I don't know if this is pertinent, but I could not use a USB 2.0 hub while my M6811 was plugged in. A USB 1.1 hub worked correctly. There was some short or noise being generated in the system. I had similar problems with an external USB 2.0 HD used for backups. I traded in my lappie for a new M6811 and the problem went away!
- 6809 Firewire Problem
Currently, there are 218 Active Users
(2 Members and 216 Guests)
Recent Discussions
- › BloodMasque 5 hours, 18 minutes ago
- › (personal) Worthy Free Updates of the Day. 5 hours, 30 minutes ago
- › Firefox Browser 5 hours, 34 minutes ago
- › MY ALIENWARE m18X r2 6 hours, 6 minutes ago
- › How much is my M18x valued at? 6 hours, 7 minutes ago
- › Zoner Photo Studio 15 HOME 6 hours, 12 minutes ago
- › For freewares hunters 6 hours, 12 minutes ago
- › Acer Aspire 4935G Random Shutdowns, Not Charging when turned on 6 hours, 21 minutes ago
- › Google Chrome: Open Source Web Browser 6 hours, 22 minutes ago
- › Where minds meet 6 hours, 37 minutes ago
View: New Posts | All Discussions
Recent Reviews
- › Lenovo Yoga 13 IdeaPad Convertbale Ultrabook (tablet) 13.3"... by The Bard sRc
- › Alienware M18X by MrFox
- › Kensington Black Contour Pro 17" Notebook Carrying Case Model... by great white
- › Lenovo W530-24382LU i7-3720QM 2.60GHz 4GB 500GB 7200rpm NVIDIA... by Djembe
- › Kingston 8GB (2 x 4GB) 204-Pin DDR3 SO-DIMM DDR3 1333 Laptop Memory by Nicadraus
- › Synology DiskStation 1-Bay (Diskless) Network Attached Storage... by Mr T
- › Barnes & Noble Nook Color by sewshoplady
- › Cooler Master CM Storm Spawn 3500 DPI Optical Sensor Gaming Mouse... by Rotterdamblues
- › Samsung MV-3T4G4 4GB DDR3 Laptop SDRAM (1333MHz PC3-10600) by Rotterdamblues
- › Alienware Aurora m9700 by amythompson172
View: More Reviews
New Articles
- › Intel Summer 2012 SSD Scavenger Hunt - Full... by ranjanis
- › Intel's Maple Crest 330 Series Promotion... by ranjanis
- › Intel Cherryville SSD Spring 2012 Giveaway by ranjanis
- › Intel Cherryville SSD Giveaway 2012 - Terms... by ranjanis
- › Advertise by jdz2287
- › Search And Advanced Search Tutorial by NotebookForums
- › Tagging Tutorial by NotebookForums
- › Add A New Item Tutorial by NotebookForums
- › Image And Video Tutorial by NotebookForums
- › Subscription Tutorial by NotebookForums
View: New Articles | All Articles
Home | Reviews | Forums | Articles | My Profile
About NotebookForums.com | Join the Community | Advertise
© 2013 NotebookForums.com is powered by Huddler Tech | FAQ | Support | Privacy/TOS | Site Map
