6200 Pcmcia
post #1 of 2
Installed Windows 95 on naked system. Everything setup just fine except there is an ! on the PC slots. I checked Sager's driver info, but the only thing they had was a "patch" which you add in the Win.ini file:
load=blah.com (can't remember the exact filename)
I DLd the .com file, and added the line to Win.ini but no help.
HELP!
my e-mail is doug@dougblakely<remove>.com
post #2 of 2
Check the system properties and go to the advanced tab, PCMCIA mode might be in 16bit mode, or there could be a conflict.
  Back to Forum: Drivers
