I don't understand why this thing stays so hot. In an effort to cool it down, I did as some recommended here, took the keyboard off, cleaned underneath. Took the plate under the keyboard off and made sure there wasn't lint or stuff there, vaccuumed that out.
Removed the underside compartments and vaccuumed the fan and heatsink areas.
Everything looked clean when I started, but I went thru the motions regardless.
While the metal heatsink plate was off ( the one under the Keyboard) I even put a micro layer of artic silver on the chip contact points for the cpu and gpu, but left the thermal tape that was there in two areas for other items.
Upgraded the bios to 1.00.10 and upgradd the ATI drivers to the 8.04 which require the bios upgrade.
I have the laptop angled up in the back, to where the back bottom edge is 1-3/4" off the desk. No vent obstructions. As soon as I turn it on, the fans go into high speed mode.
Mobmeter still shows between 46-48C during idle.
What is the FN+F10 key supposed to do, as I do not think mine works. Unless it is to kick the fans into high speed, at which my fans are always on high speed from the time it boots.
Is there any way to cool this thing down or to turn the fans down?
I just booted it up, and as soon as it went into windows xp, the fans are at full speed, and mobmeter shows 41C at boot.
