5400, 7200?
post #1 of 6
Just a quick question. How much of a difference is their? Is it WORTH the extra 100 bucks?
post #2 of 6
if you have the money to blow, i'd go for it. however it's doubtful you will notice a difference in speed unless you use disk intensive applications; video editing and the like
post #3 of 6
Most desktop hard drives are 7200 so if you are looking for a complete desktop replacement then go with a 7200 rpm drive. However, hard drive speed may not be your laptops bottle neck. If you get a new Sager with a 5400 rpm hard drive though the drive will be the systems weakest component.
post #4 of 6
7200 rpm will also suck the juice out of your batteries faster...if you wanna go mobile...go with a slower hdd.
post #5 of 6
Surely, a 7200 drive will boot the system a lot quicker ?
That's a big plus, as far as I am concerned.
post #6 of 6
yes in real-life use I read that the 7200rpm HD does make a big difference
although I'm not sure how much juice it will suck, no offense, but I also read that the 7200 pulls about the same power as the 5400
so why not I say?
  Back to Forum: Sager & Clevo Notebooks
